jbrehmrn
- November 7, 2008
- Points
- Iowa
- 1999 Mountaineer
Anyone have any idea how you can tell a viscous coupling problem vs clutch pack problem in the rear end. I have a shuddering with low speed turns that seems to come from either transfer case or rear wheels. I changed out differential fluid twice adding appropriate fluid and anti friction fluid. Then I chnged transfer case fluid out, but I did notice flecks of a different color fluid mixed with the trans fluid. It was more gray to metallic in color. Could this be leakage from the viscous coupling. Is there a way to test coupling vs clutch packs?
