Tshark299
- October 29, 2004
- Upstate NY
- '93 XLT
So over the past 2 days I went from knowing nothing about AC systems to being very well read on them thanks to this forum. My system was converted to R-134a some years back by the previous owner and recently had started cycling every couple seconds first only at higher RPMs, then at idle as well.
So I got manifold gauges and a 12oz. can of 134a and learned how to add refrigerant through the threads on here. I'm just not sure if my final pressures are good.
With outside temps around 85°F and engine RPMs at about 1500, the compressor was no longer cycling and my pressures were about 40 on the low side and a little under 300 on the high. I let it run about 10-15 minutes like this, afterward the low had dropped to about 30psi and high was just over 300. The compressor ran continuously the whole time.
So how good or bad are those numbers? I found one chart of low pressure ranges for given temperatures by searching but there was some debate over the quality of the chart later in the thread. So how am I doing so far?
