07EddyB
- November 18, 2011
- Bowling Green, KY
- 2007 Ford Explorer 4.6 V8
Lots of talk about the single bolt in the rear diff and how it would mostly affect the Explorers with the larger engines due to the increased torque available.
So - a little mental exercise - what about the Timberline with the standard limited slip differential? I understand that the engine torque is the same as all the 2.3L engines - but if you can put that torque more effectively down on the road then wouldn't that increase the load on the differential?
I haven't seen an option on an ST for a limited slip differential - so I am assuming at this point that it's counting on the 4WD system to get a hard start without just spinning one tire. Which of course would spread the engine torque out between the front and rear wheels.
But what if the rear can grab with both tires? Would that mean that the 4WD system would kick in slower and more of the torque would be concentrated into that rear diff for a longer period?
I'm not going to pretend that I understand the dynamics of this thoroughly but I wonder if the Timberline might be as vulnerable as the ST or the police units.
