I have a 2000 Mountineer 5.0L AWD 3.73 Posi rear (100,000 miles too - but I just bought it so not sure of the history. It has never towed (no "witness" marks on bumper from the ball) and I did not see any marks underneath from a hitch. The trans fluid is pink and does not smell bad.
IT has the "light" trailer tow package when made. I saw there is a 8" x 10" trans cooler in front of the radiator that looks to be factory.
According to charts and information - I can tow up to a total of 6,400 pounds including weight in the vehicle.
I will be towing an enclosed trailer (5 x 8 or 4' x 8 depending on availability), holding a dining room (table 8 chairs, breakfront and base) set about 1,000 miles - some flat some with hills but not steep mountains, but all interstate.
From what I read the hidden Hitch Class 3 is the preferred set up and it seems that is pretty easily installed to boot.
I am a bit confused with all the talk about additional trans coolers - do I need to add one? If so, where? Yes, I know the trans is probably the weak link, although this truck has a 4R70T in it. Could someone please help explain that part of it?
Also, is it worth getting the adjustable height draw bar? As I will be renting trailers not using the same one?
Thanks for your clarifications.
