SportsTrac2001
- May 24, 2009
- Left Field
The history first:
Replaced fuel pump last year, less than 5K miles ago, Tried starting it the other day, would not start. Disconnected battery to reset whatever (reboot memory?). It started right up after that. Drove around no other issues.
Next day it would not start, disconnected battery tried to start it and it would not start, left it for the day and came back later 6 hours and it started right up, drove around no issues.
Next day got in car started right up, went to work.
Yesterday tried to start it and will not start. undid battery no luck, let it sit for a day no luck.
Went to Advance Auto bought what I thought was a fuel sensor relay (BWD R3177) change all the sensors out in that panel under the hood with no luck.
Checked the Inertia switch it seem OK don't know if it should be pressed in or popped out?
Questions:
How can I can the Fuel pump without dropping tank.
What other sensors affect electricity going to fuel pump?
What are that suggested troubleshooting steps to firgure out when the problem is.
Any help would greatly appreciated.
Thanks
Charlie
Questions:
Thanks
Charlie
