LMHmedchem
- October 28, 2011
- 2002 Explorer XLT v8
Hello,
I have just finished up several repairs on my front end. I have what I think are good references for the engine torque settings but I find that the numbers for the suspension come from all over the place. I would like to make sure that I am using the correct numbers.
These are the numbers I have used,
front axle nut (1 spin nut): 184 ft/lbs
front upper control arm to frame (2 nuts): 83 ft/lbs
front upper control arm bushing (2 nuts): wrench tight (I have not found a value for this)
front hub to knuckle (3 bolts): 83 ft/lbs
front caliper bracket to knuckle (2 bolts): 83 ft/lbs
front caliper slide pin (2 bolts): 24 ft/lbs
front brake hose banjo bolt to caliper (1 bolt): 26 ft/lbs
front caliper bleeder screw (1 bolt): 15 ft/lbs
front upper ball joint (1 nut): 41 ft/lbs (this seems a bit low)
front lower ball joint (1 castle nut): 83 ft/lbs, plus any extra to expose the cotter pin hole
front outer tie rod end (1 castle nut): 75 ft/lbs, plus any extra to expose the cotter pin hole
front sway bar link (1 cap nut): tighten until the bushings compress some
front upper strut to frame (3 nuts): ???
front lower strut to lower control arm (1 bolt): ???
Fasteners were torqued with the lower control arm jacked up to ride height, which I measure to be 4.75 inches from the lower control arm up to the frame right next to where the front cross-member attaches to the frame. This excludes the caliper bolts and the axle nut. The axle nut was torqued after the tire was reinstalled and the truck back on the ground (so also ride height but not simulated with the jack).
The nuts that hold the upper control arm to the frame and the upper control arm bushings are the values I have the least confidence in. I have not looked up the values for the upper and lower strut bolts because I didn't change out the strut.
If anyone has any Ford references that they could post, that would be a big help. Otherwise, please let me know if anyone thinks that any of these values are off or if they can provide any of the missing values, including those for the strut.
LMHmedchem
LMHmedchem
