Seahawk
- December 12, 2009
- Washington State
- 03 explorer Centennial
Hi. My 03 4.6l Centennial with 270,000 miles recently began not starting. It has a fast clicking of the solenoid. Easy to jumpstart and after starting will run as normal (everything is bright and works normally). Turn it off and it clicks again. Battery is two years old (yes, I always keep it filled with distilled water. I am not "that" guy). I have noticed the passenger side headlight sometimes has to be "helped" to turn on after getting truck started. I would normally think solenoid except it starts with a jump (same for starter). Terminals are all shiny and NO corrosion to be found. Ground problem somewhere? I am still looking and taking headlight apart when weather/time cooperate. Have you had this problem?
