David V.
- January 30, 2017
- Long Beach, CA
- 2003, Sport Trac, XLT
My 2003 Sport Trac with 165k miles has recently started to pulse at idle on a cold start, with the pulses smoothing out with 30 seconds or so. Although the revs hold constant at ~1000rpm, it feels as if someone is pumping the gas. The problem is most pronounced if idling in gear (forward or reverse), though will also occur while in neutral.
Extra Notes:
The check engine is not on.
I tried replacing the IAC and have cleaned the MAF, but this hasn't seemed to help.
Has anyone else had similar issues or have any suggestions?
Thank you!
Extra Notes:
Thank you!
