JohnyFixit91
- October 24, 2023
- Pendleton Or
- 2015 Ford PIU 3.7L
Alright an update, Got my Remote Start to work, added Hood Switch & Enabled Remote Entry/Start options, bought x2 Fobs for $35, 50ft of distance, not terrible.
As for the Sony FCIM I could only determine 2 wires on the circuits, 2 are Can bus, but I can't tell polarity, the other 2 wires may be for climate & Heated Seats I don't know. Here are some photos of the circuit showing my sloppy drawings to the PINs & to the Chips/Resistors/Transistors. In the top right corner you see the Chip, 1st pin goes to one Can bus while the 3rd one in goes to the other.
Also a couple Photos identifying 6pin flat connectors on the FCIM from a 2012 Exp Limited (8" Sony) & my 2015 PIU (4" Non-Sony) different wire colors is all. Both have the same Steering Wheel Controls for Sync/Phone. Now I don't have any Electronics from the 2012 relating to the Screen/APIM/FCIM, but I figured it could help those who do.
Now my question is, would Wiring the Can +/- buses backwards do any harm? Seems like I have a 50/50 Chance of getting it to function.... Uncertain if these are MS or HS Buses, which use different voltages I believe, shouldn't be an issue unless I'm shorting it out...
By the way this Green Circuit Board is the 2015-2017 8" Sony FCIM
