dluthuangj
- April 24, 2023
- Peachtree City
- 2014 Explorer XLT
Hi, I have a 2014 Ford explorer XLT 3.5 L. Three months ago, the low oil pressure warning light was on when I was driving and the engine stalled. I pulled over and restart the engine after 1 min. Everything was fine and the low pressure light was off. I drove it home without any problem. The engine oil level and conditions were both fine. So I didn't do anything but kept an eye on the vehicle. Last week, this symptom appeared again. After I restarted the car, everything was back to normal. Anyone had this experience?
I doubt the oil pressure sensor causes the problem. I tried to replace it on my own but it is hard to disconnect the switch connector on the sensor due to the tiny space around the sensor. An auto shop asks about $400 to replace the sensor because they said the oil cooler needs to be removed to have access to the sensor. I watched some videos on youtube about replacing the sensor on 2013 or 2015 ford explorer. I didn't see the oil cooler around the sensor and their method doesn't work on mine. Is there anyone can replace the sensor without removing the oil cooler on 2014 ford explorer?
Any input will be greatly appreciated!
Thanks,
Thanks,
