kmac99
- April 26, 2023
- Copperas Cove Texas
- 2013 Explorer
First post, I searched to see if has been asked and didn’t see anything with my exact situation. So here goes.
Neighbor had transmission failure in is 2013 explorer. He bought a 2016 interceptor with low mileage so we could swap the engine, trans and transfer case and I realized today they weren’t exactly the same. I did the reading and found the differences in the motor and will swap the harness. I’m also swapping the trans and transfer case with this unit and see that the new one is cooled and also has a sensor pigtail. From what I can tell the electrical connector is a temp sensor. If I am correct on that, then I believe all I need to do is just secure the wiring out of the way and not worry about putting that in because the 2013 does not have any sensors. My bigger question is the cooling lines, is it as simple as I just need to plumb them to the cooling system? From what I can tell these are sealed transfer cases so I believe it’s coolant that only circulates to cool the unit. Hopefully someone else has already done this and can line me out. Appreciate any help.
