Bill MacLeod
- November 18, 2000
- Hamilton, Ontario
- 06 Ltd V-8
What I use is Motorcraft Spray Carburetor Tune-Up Cleaner in a 1lb 2 oz (510 gram) spray can. Works great for me, bought it a a dealer across the border.
Sure sounds like you had put enough torque on that plug, obviously you were able to break free the other 7. I recall the back plugs on each side were the most difficult to get out.
I used a 1/2" drive torque wrench the first time changing plugs set to 33 ft lb. Brake free approx 1/8 to 1/4 turn, cleaner to top of plug hex, let soak for 1/2 hour, work back and forth much just like cutting threads with a tap. All with engine at around ambient temperature. (75 to 100 F)
You might want to try a 1/2" drive torque wrench. Will have lots of leverage. Beg, borrow or buy one if you don't have one. Its a tool that has many uses.
Anti-seize on the new plugs?
