adambomb946
- November 14, 2008
- Burke, Virginia
- 04 XLT 4X4
Its easy to get the 3rd screw back in. Just get a battery side post ratchet. Thats the best way to go.
I'm also about to undertake this and would love the pics.
My wife is cold!
The blend door repair kit is for 2001 and earlier. THat's why it doesn't look like the pictures
first I need to know if you have manual or DATC Climate Control System?
Take the steering column off (3)
Get on your back on the drivers side floor and you will need to take out the 3 screws on the actuator. There hard to get at but it can be done. Pull the power plug out of the actuator and then just wiggle it out. When you reinstall it you will only be able to get 2 screws back in but they hold it just fine.
Does the above info apply to the dual driver/passenger climate contol system in my 2002 Eddie Bauer Explorer? I am getting partial heat and can contol the heat from cold/cool to slightly warm but no better. Am thinking it must be the blender as the input and return coolant lines are getting hot so coolant circulation seems to be ok. Just want to get all info I can before I jump into taking the console apart.
The dual climate systems have a divided air box and two blend doors, one for passenger side and one for driver side. Does either side work correctly, or does one side get warmer than the other side?
