caplbi
- January 27, 2011
- pine brook, nj
- 1998 xlt
I'm new to this forum so I would like to say hello to everyone. I belong to a marine forum so I know these are very helpful.
I acquired for free a 1998 explorer xlt 66k miles and a 4lt v6 motor. The truck sat for over 2 years due to a no start problem and broken rear brake line.
After fixing the no start problem ( bad fuel pump ) and break line the truck ran very rough as I expected it would until I ran out the old gas.
As I added new gas and new filter and fuel system cleaner, the performance did not improve. So I started changing parts.
New plugs and wires. Not motorcraft. IAC valve, Throttle position sensor, crank position sensor, air filter, cleaned the MAF sensor, removed the throttle body and cleaned. I did notice that there was no gasket for the throttle body.
The truck is running better, still stumbles at idle and hesitates at 40mph, and struggles on hills with just the driver in it.
I read here that it might be a vacum leak and I think I hear one but cannot isolate the area. Any suggestions? Is there supposed to be a gasket between the throttle body and plastic intake?
