Banjoes
- May 25, 2012
- Florida
- 1995 Ford Explorer XLT
Hi i have 95 explorer xlt 2wd 4.0l v6 OHV and I have a rough idle and throbbing/surging acceleration at part throttle when under load (accompanied by a small whistling noise) but accelerates fine above 2200 RPM.I can accelerate to WOT with no performance hickups. By the way there is no Check engine light on.
Tried so far:
Fuel filter replaced with motorcraft filter in 2011
Fuel pressure regulator replaced with BWD today
Idle air control valve replaced with BWD 2013
DPFE sensor replaced-codes 335 and 332 in 2012
MAF sensor cleaned in 2012
spark plugs (not wires) replaced in 2009
thermostat replaced along with coolant temp sensor(gauge only)-2013
Throttle position sensor replaced with BWD in 2013
Throttle body removed cleaned with TB cleaner and toothbrush (new gasket o-ring) and even took IAC off and cleaned IAC passages on intake manifold.-something of note here, when taking off throttle body the bolts were loose (the bolts felt like they barely had any torque on them)
I think I'm leaning towards maybe new spark plugs, wires and maybe coil pack
I've checked for vacuum leaks by spraying carb cleaner around various intake areas especially around the upper intake manifold o-rings-nothing
I'm open to any suggestions, please Help!
Tried so far:
