blakshukvw
- July 14, 2009
- K.C. mo
- 2001 Explorer XLT 5.0
My 4r70w has been starting to shudder going into OD recently. It only shudders shifting up into OD, never at any other shift point. I can make it not shudder by easing out on the throttle before it makes the shift. I'm thinking of performing a trans service with a fluid and filter change as it hasn't been done in 25k miles. Is it okay to use the Lubeguard Highly Friction Modifier with MercV or is that solely for use with MercIII? I'm looking to try to resolve this issue this way first. Anyone have anything to say either way about this? Am I headed in the right direction or should I look at something else?
Here is the product I am referring to,
http://www.lubegard.com/~/C-177/LUBEGARD+Highly+Friction+Modified+ATF+Supplement
Also, should I drain the TC or just the trans when I perform this service? How do I drain the TC?
