tristram77
- October 11, 2000
- Staten Island/ Boscawen ; NY/ NH
- '92 XLT 4.0
I have a question about the following:
a test you can perform to the processor board that is located in the rear left access panel next to the jack and rear windshield washer container. In has 2- wire harness pin connectors attached to it on the left side. If you remove the 2- wire harness pin connectors and turn on your ignition switch. Now you can push the white square button on the bottom edge of the processor board and it will turn on a red LED right next to the button. If the red light flashes this means you have a problem with your actuator motor assembly. If the red light stays bright this means you have a problem with the processor board.
Does anyone know if this is valid? MY 4wd stopped working at the push button. I have manual locking hubs and have opened and cleaned the transfer case motor (I am hoping this problem can be fixed by just doing that again)
What would it mean if i had a problem with my processor board. Seeing that red light stay fixed feels like the kiss of death to me.
