verno316
- February 2, 2015
- oshawa
- 02 explorer
I have done a search on here about the flashing 4X4 high light and I have read a lot of good info here but I'm not sure which of the most often repeated solutions to try first. 2002 Eddie Bauer, last night on the way home from work the 4X4 high light was flashing 8 times. Truck drove just fine, but the light would keep flashing every few minutes. Driving around town today no problems but the ABS light was on. The ABS light seems to come on during cold weather, it will stay off if the truck is restarted after being warmed up. Then driving into work it drove fine on the highway for about 40 minutes. When I got off the highway and went through a drive through I could feel "chattering" during slow speed sharp turns like it was in 4X4 and when I stopped there was a clunk in the back end and the 4X4 light started flashing. When I drove away, it drove fine but the light kept flashing. I haven't had the ABS light on at the same time the 4X4 light was flashing but it is on frequently. The check engine light is not on. I have a code reader but it doesn't do transmission codes. Would the there still be a stored fault code for the transmission that doesn't cause the check engine light to turn on? Are there any other tests that I can do to determine if it's a sensor that needs to be replaced or if it's the 4X4 module in the glove box? I have limited mechanical abilities, the module I could do myself, the sensor I may need to have someone looking over my shoulder.
