lksdrinker
- October 24, 2009
- 2000 mountaineer 5.0
New guy to the site with a couple of questions. I've been lurking for a while now whenever I was doing some repairs....most recently when doing a heater core, radiator flush, blower motor repair, spark plugs, etc.
I've got a 92 Explorer and cannot diagnose my 4x4 problem. Nothing happens when either button is pressed on the dash. So I went to the rear hatch and pulled the two harnesses from the 4x4 module and after pressing the reset button the LED flashed 4 times and stopped. Plugged the wire harnesses back in and then I took apart the dash switch. The switch is currently connected but the front panel/buttons are not. If I use a test probe light I can get the switch to work...ie there are three contacts that when hit will lit up 4x4 high, low, or just the solid light on both the dashboard and the switch. But when I get those to light up I cannot hear any relays clicking anywhere.
In any event pressing the buttons will not make anything happen...no lights on the dash or switch and no clicking relays anywhere.
So I cant figure out what to look at next? Is there a better way for me to test my switch...can I measure resistance across certain terminals with a multimeter or anything like that? Are there any relays near the 4x4 module that I can try swapping out? Should I just look at doing the shift motor rebuild to see if that helps?
