- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
Rebuild and Internal Upgrades
5R55E Valve Body Rebuild Diary
5R55E - (Companion Thread to the 5R55E Valve Body Rebuild Diary)
FrankenTranny Hybrid A4LD - 4R55E - 5R55E
Frankentranny companion for the 5R55W
5R55W Solenoid Block Replacement w/photos.
5R55W transmission servo piston removal
5R55E internal thermostat bypass how to
How To: 5R55W Solenoid Block Replacement w/photos
Diagnostics
5R55E 2-3 shift flare issue
5R55E OBDII Diagnostic Codes
Maintenance
5R55W Fluid Fill
Transmission Swap
5R55S Swap
Diagnostics
Maintenance
5R55W Fluid Fill
Transmission Swap
5R55S Swap
