zerodevil
- March 24, 2008
- Anchorage, AK
- 2008 White Limited V8
Alrighty lads, i have been posting a little about this on the 3rd gen modified section with no leads to speak of, so i am bringing it on over here. About a month ago my 5r55w finaly failed on me (no 2nd or 5th, was accurately diagnosed as OD servo bore ware). I Had the Transmission rebuild AS NEW, along with a TCI hardened input shaft, TCI Jumbo OD, and intermediate servo, a superior-transmission shift correction package, and a performance automatic deep dish pan with a custom extended pick up tube. I also bolted a brand new TCI 2500 stall brakeaway torque converter to her, with lock up. Long story short the truck seems to run and drive great, but if i am cruising at any speed over 45 mph for more than 3ish minutes i get trouble coude p0741 " torque converter clutch stuck off". I imediately had the truck returned to the shop where i was told after a live feed data-moniter that the truck was just detecting to much slip from the torque converter, and that the transmission is doing everything it is supposed to. I asked my tuner about this and he claims that in many mustangs this code has never reared its butt ugly head. I believe the transmission shop has a conflict of interest given they may be the ones that messed somthing up (shift kit is where my money is at). Well, last thursday the truck blew the front cooler line off of the ATF cooler, i again had the truck returned to the shop (not 24 hours after they gave it a clean bill of health). They pulled the pan and did an inspection of the trans, thankfully nothing was fried, and they also refilled the transmission with 10 Qt's of royal purple for me, all free of charge(blamed the blow out on an old clamp, ruber lines rather than hard lines, and 3x fluid to the cooler from the shift kit mods)(also advised me to upgraded to braided steel lines and AN fittings). This time i had them hop into the truck with me and let me drive them around while they did an active data moniter on the truck, and confirmed for me that the TCC is indeed engaging when it should be, and that the code p0741 is spawning from the PCM detecting to much slipage in the TC when the TCC is engaged. has anyone else had this sort of problem from the 5r55w after the superior shift kit was installed? i have no way of knowing or comparing the kit with out having to purchase another kit and then to rip the valve body out to look at it.. Again the truck shifts smooth as silk and runs a full 25 degrees cooler than before, but i get that crazed light after i hold high rates of speed in OD. advice? shift kit or torque converter? or tune?
