sonicblue
- November 15, 2009
- MI
- 2003 FX4 LII
I just had the pinion flange nut backoff about 2 years after changing the pinion seal, so this time I wanted to change to a solid spacer to end this problem. I got the Raytec IK4105 kit and noticed the solid spacer ID is a pretty sloppy fit on the pinion, but I talked with a shop and they said that was normal. I measured the old crush collar and ended up with a stackup of about 0.010 less to get to the correct preload. I figured this was probably do to some springyiness in the collar since it's now unloaded. The Raytec kit comes with shims for 0.020 through 0.050 in 0.002 steps, but I only needed about 0.010 so I couldn't get into the normal shim range. I machined the solid collar down 0.012 and got a good reading using 0.022 shims, about 8in-lbs. I put it all back together, drove it on the freeway for about 10 miles, came back and was shocked to find I could hardly turn the pinion it was so tight! I pulled it back apart, redid the shimming, and now I need an 0.030 to get 8in-lbs of preload.
WTF??? How could this change? The axle was very hot when I started reshiming and cold when I was done but this didn't seem to have an effect on the preload which is what I would expect. I then drove it again on the freeway for 10 miles and it seems fine this time, but since I can't figure out what happened, I don't have a lot of confidence in my setup.
Sorry for the long post but this has be stumped. Has anyone else ever seen this issue?
BTW, I have setup dozens of axles over the years and this is the first time I have ever seen anything like this happen.
One other note, I'm torqueing the pinion nut to 200ft-lbs. There is no torque spec for this nut since you are usually crushing a crush collar, I thought this was reasonable. Maybe it's too much?
Confused,
Darryl
Confused,
Darryl
