(92) no 1st or 2nd gears after clutch replace | Ford Explorer Forums - Serious Explorations
mdfisher
I just replaced the cluch in my 92 explorer. First time ever replacing clutch.After replacing the clutch I am now not able to put the truck in 1st or 2nd gear. During the disassemble I removed a sensor opposite of the reverse switch. I later discovered I did not need to remove. If I now remove that switch. I can get the truck to go into 1st and 2nd gear. When I put it back in, it will not go back into gear. Is there a certain gear it must be in when I put it back in. Or did something slide out of place th needs to be fixed as well. Also 3rd, 4th,5th and reverse are working fine.
