louisianaqueen
- May 7, 2016
- 95 ford explorer 4.0
My husband has a 95 explorer 4.0 that we just can not get to run right. It is idling rough. It is hesitating to accelerate. The rpm's when coasting will drop almost to the point of the engine dying but just before it dies the rpm's will pick back up.
Everything we have done so far.
Had the cylinder heads checked for cracks and to see if they were warped. (they were warped so they were machined down the guy that did it didnt tell us how much he took off)
Replaced all the gaskets from the heads up.
Brand new injectors
brand new fuel rail
brand new fuel pressure regulator
new plugs
new plug wires
new ignition coil
new mas air flow sensor
new throttle position sensor
new fuel relays
new EGR valve
new EGR valve pressure sensor
new pcv valve
replaced all the vacuum lines
new air filter
cleaned the throttle body
new egr valve tube
new idle sensor
new fuel filter
did a oil change
new oil filter
new fuel pump
We are at a stand still and do not know what else could be the problem with this truck. Any help is greatly appreciated.
Thank you in advance
Brand new injectors
brand new fuel rail
new plugs
new plug wires
new ignition coil
new fuel relays
new EGR valve
new pcv valve
new air filter
new egr valve tube
new idle sensor
new fuel filter
did a oil change
new oil filter
new fuel pump
