EB4X
- December 28, 2016
- Orange county, Ca
- 95 Explorer 4X 4.0 ohv
Hey gang,
So lingering gremlin....installed new IAC / fuel regulator / camshaft synchronizer assembly -- CIL code was on for this -with this repair new upper plenum and fuel rail gaskets / new fuel injection o-rings where installed / also tried new throttle position sensor but coincidentally made vehicle run worse then used oem - chinese part.
So with hood popped open and manually giving engine some throttle by hand (for close observation) there is a DELAY at beginning of throttle acceleration accompanied with a wisp / hiss sound for a second. Anything in particular come to mind? Bad rubber throttle body gasket? Idles good for the most part but occasionally will go into a temporary rev up and down during first start up of the day-- in a mild way and then goes away -- and rare at this....which makes it a stumper. And with this situation occasionally will die if doing quick acceleration from stop.
'95 has old school OBD1 so don't have all the elaborate testing options.
