greasemanicure
- November 1, 2006
- Burlington, NC
- 1996 4X4 4R->5R mod
Daughter drives a 96 Explorer, 4WD, 4.0 6Cyl that started to show some transmission symptoms.
1) First symptom was a bit of a shudder going into reverse.
2) This tended to happen when warm rather than when cold.
3) As we have had this truck for about a year with little knowledge of maintenance, dropped the pan, changed filter and fluid. Fluid was a bit dark and smelled burnt. Fines on the magnet and nothing else in the pan or fluid. Did this about 3 weeks ago.
4) Last week shifts to overdrive started to be sloppy with hi revs. Reverse got slower going in and would sometimes slam in at about 2k revs.
5) Last night reverse shuddered its last and quit. OD light flashing sometimes as well.
6) Pulled the codes with a P0761 "Shift Solenoid C CKT Performance or Stuck off". OD seems to kick in going downhill. Seems to be no engine braking.
7) Fluid is at the full mark, clear red with some residual "sootiness" from the partial change with the pan drop 3 weeks ago. No smell to speak of.
I might be tempted to do some or all of the work myself (more adventuresome these last few years). What further might I be able to do to diagnose and identify the problem(s)? Can I get over equating AT work with brain surgery?
