mcicardo
- February 13, 2010
- 97 XLT 5.0 AWD
I have just bought a 97 Ford Explorer XLT 5.0 AWD that has 195000 miles. The check engine light is on and it had two fault codes. An O2 sensor fault (which I cleared by replacing the Downstream, Pasenger side sensor) and it also has a EGR Excessive flow fault. I took the EGR Vacuum Solenoid off and checked that it is getting 12 Volts from the battery and when checking the resistance of the actual solenoid; it reads 30.1 ohms. The vacuum line running from the solenoid to the EGR was crumbling in my hands, so I replaced it. I pulled the EGR off and cleaned it up (it didn't really ned much cleaning). I don't have a pump, but by sucking on the EGR by mouth, I verified that the Diaphram in the EGR is still working. I didn't check out the EGR Position Indicator sensor on top of the EGR, and that is going to be my next step. I did notice that the gasket for the EGR was no there any more. I got a gasket kit and carved a new gasket for the EGR valve (none of my local auto stores carried the right one) and put everything back together. Went and cleared the codes and drove for about 10 miles with no issues. The next morning, I started driving and got maybe a mile before the Check Engine light came back on with the EGR Excessive Flow fault.
Any help with what my next step needs to be, or a better way to check these componets would be greatly appreciated.
Mike
Mike
