97 ford explorer and 00 mercury mountaineer door swap? | Ford Explorer Forums - Serious Explorations
97 ford explorer
Hello I was wondering if the doors off a 97 ford explorer would fit a 2000 mercury mountaineer? Also what other parts would be compatible with the mountaineer? Thank you!
They'll bolt on but the wiring harnesses are different, as well as the body trim and lines, if you're not picky about either, then they will bolt up and close, if they're both the same drivetrain, then the engine will fit, transmissions differ between those years, rear axle might, not sure on that one.
