Okay then, the fabrication starts there. I had a plan to make the 2003+ switch work, but I'll wait to see what the 97/98 part needs. I bought a GEM and switch yesterday on eBay, my local yard that I like may or may not have one before I'd need it.
I will need the wiring pigtails from an Expedition for the GEM though, did you think to get those Mickey? Where were the TOD and 4WD modules, the TOD is a pain to pull from an Explorer? They likely are identical in usage and common. I'm glad some of the rest of you have better parts sources, you can lead the way. I'll be a while before I may get into the GEM project, I have a lot to do for just swapping engine and trans yet.
The 97 switch I have will work with modification to the bosses, or like you mentioned earlier a metal clocking ring that you screw the Expedition knob housing to, and then clock it properly & screw it to the back of the Explorer bezel. Only asthetic issue then will be we have a four position switch, but the dash bezel only shows a place for three. Minor in my book.
I didn't think of the pigtails 'till I was halfway home, but I rather doubt either truck had them anyhow - both the Expedition & the F150 looked like someone cleaned out the dash area with a chainsaw. The GEM in the F150 was actually unlabeled and tossed in the rear of the cab, so I'm only guessing it's from the F150. BUT, those GEMS plug directly into the rear of the gigantic fuse block, and then pigtails come out - so, we'll only be able to get half the pigtails anyhow, we'll have to modify something to plug into the back of the GEM where it mounts to the fuse block. Guess I could take apart a fuse block & see if that turns into a pigtail, didn't think about that...
The TOD and 4wd parts are on top of the dash - the Expedition appeared to have a traditional dashboard which you could remove the top of (gone by the time I got there so I'm purely guessing) versus the Explorers one piece job, and those modules are right where the center speaker was on mom's '77 Malibu. The modules are both mounted to a small metal bracket which is easily removed, complete with a single pigtail. No airbag removal here, tho the TOD doesn't have the stud like our Explorer one does, so the mount will have to be modified - again, not a big deal I don't think. BUT, all the wires are different colors on both modules, so I don't know if they will interchange or not - plugs look right, so they may plug into the frankenstein wiring harness we come up with for the GEM anyhow.
BTW Don, the cheapo U pull it yards in Denver are where I have the best luck - Gen I and Gen II Explorers out here are a dime a dozen, about worthless in value unfortunately, so most I find aren't even wrecked, they just have "no emmisions" spray painted on them & wind up whole in the wrecking yards, owner unwilling to invest the $500 or whatever to fix them. May want to check the U pull it places near you where they don't even catalog these trucks.
