dflickinger
- June 26, 2009
- kingwood, Texas
- 91,98 explorer, 95 aero
The 98 explorer xlt 5.0, is 1-1/2" taller on the passenger side, measuring from the centerline of the tire to the bottom of the wheel well there is a difference between the passenger side and the drivers side of 1-1/2". The car looks like is leaning to the drivers side. I have checked the measurements at the ground to the suspension to the lower tie rod and there is only an 1/4" difference. Also the passenger side sway bar is loose, you can spin the bolt by hand. all bolts are tight. send your ideas for me to check
