- February 2, 2002
- 1998 Mountaineer AWD
For the oil leak check the rear main seal, it's fairly common on the 5.0s
Its losing oil somewhere above the driver side strut tower, but it is also losing a little bit above the water pump near the intake manifold. Its an odd spot, but nothing about this car matches what I have found for common issues. the guy that owned it before me was an AmsOil vendor, and maintained it religiously, and I am the 2nd owner. (except for the 4th wire on the plug wireset evidently. lol)For the oil leak check the rear main seal, it's fairly common on the 5.0s
That makes sense that the wire for number 4 has the longest heat shroud. Mine is a 99 not a 95, so it could be later enough to fit what you are saying.Don't know about the 95, but on later V8 engines, the #3 and #4 wires are the most affected by exhaust manifold heat, and have shields on them to help. If the situation with the tubular manifold on the OP's engine is anything similar, that most neglected #4 wire is also the one in the worst condition. The usual failure mode is arcing through a crack or pinhole in the insulation to something metallic in the vicinity.
It just sucks that I'm back to square one. Ill get that last wire no problem. Now I am debating if it's either fuel issues, coil pack systems, or a head gasket leak? I'll do the fuel filter this week.
One thing at a time. You're only hurting your progress and making the topic unfollowable by going back and forth like this. Do the wires. `100% finish that and confirm all deliver spark. Nothing more. Completely rule out each subsystem one at a time.
Is it random now? Looked like cyl. 1. If a grounding problem then I would suspect all would get random misfires, except I still don't agree that the coil pack needs any ground through the bracket. Its electrical function is handled by the wiring. It has 3 pins (on each of the two, twin coil packs for an 8 cylinder, or 4 pins for the 3 coil packs for a 6 cyl).These random misfires make me suspect the grounding of the coil packs. They ground through the mounting bracket. Before replacing, I would remove the packs and inspect/clean the contact surface there.
