bgk
- October 21, 2018
- 1999 Explorer Eddie Bauer
Does anyone know the colors of the 3 wires that should connect to the front left Crash sensor on a 99 Eddie Bauer and/or the part # for the 4-pin Male pigtail they should be wired to in order to mate with the crash sensor's 4 hole female connector? A wiring diagram or photos would be a huge help.
Bought the truck used with airbag light 41. Finally trying to solve it and found that the front left crash sensor is not there at all. I got a new one and bolted it in place but just realized the pigtail I need to connect to the new sensor is not there. There are 3 loose wires dangling nearby that seem seem promising, but not sure which is which, nor the correct configuration to wire them up even if I did have the pigtail to do so. There are other wires in the bundle which go to aftermarket fog lamps and an ambient temp sensor so it's sort of a mess but hoping these loose wires are what I need.
The loose wires I found are "dark green/yellow stripe"; "dark green/white stripe"; "red/white stripe". (pretty dirty so could possibly be dark blue instead of green and maybe pink instead of red). Pic attached: the 3 loose wires are in the center of pic and on the right is the gray/white 4 hole connector on the new LH sensor which I need to mate them to.
Any help appreciated!!! P.S. The RH sensor is in place and it has only one wire coming from it which looks like a match for the red/white loose wire hanging near the site of the left sensor. Any help greatly appreciated!!
