WillR
- November 16, 2003
- SE, PA
Helping out my Brother today, he has a 98 or 99 with a heat problem
Blower motor works fine.
When you move the control that changes what vent the air comes out of, air flow changes correct (no vacuum leak)
Ford guy said "its got to be the valve that shuts off the water flow" $38.00 later, still no heat.
The heater hoses are hot going in, and out of the heater core.
Short of tearing the dash apart, The temp adj. knob must change a door that mixes cold air, and hot air that flows across the heater core. Looking on top of the heater/AC air box, behind the glove box it looks like there is this white box bolted to the top of the heater box, and the wire colors seem to match those on the back of the temp controler. Am I on track here? does this control the air flow over the heater core?
Thanks in advance.
Thanks in advance.
