bobwhiles
- June 27, 2012
- 97 Aerostar
Hi,
I am adding a seperate post to my previous one re: AC Cycling as I have other general questions - hoping that some one may be able to help me understand the AC on the Ford aerostar
My quesitons are at the end of this post. I give the background of the service first.
As in my previous post I decided to rebuild the AC on my 97 Ford Aerostar 4.0l w/ AUX Rear AC
The high pressure side had a hole in the hose. I am going to do my 96 which failed do to black death. I may have already replaced the compressor on the 97 a few years back but I don't remember. I did not find signs of BD on this system.
Parts: New A/C compressor (four seasons), Rebuilt low and high hose assembly that attaches to the manifold on the commpressor, new condenser, new accumulator, PAG 46 OIL "ICE", 54 oz of 134a, severe duty orifice tubes (four seasons), new fan and new clutch. (fan was craked out and fan cluth was old). ((bought everything on sale))
Service: Cleaned fins on both evap cores, repalced all the parts above, flushed system (front and rear) and blew out with dry air. Pulled vac down to 30" for 2.5 hours. Put @13oz of oil in - 5 in the compressor, 4 in the accumulator and the other in the hoses. Set compressor on face for about 1 hour to lube the seal. Turned clutch 10+ turns by hand after hoses were installed. Ran clutch in and out after it first in enganged about 10 times.
Installed full 54oz of 134a - not sure if I needed to. The system was blowing ice cold air at 24ozs. System tag said 4.25lbs. MAX guide says 54oz and the shop manual has it at 34 or 36oz - so I went with MAX per Four Seasons recommendation - shoudl I have?
RESULTS: the clutch engaged on about 6oz of 134a and air blew cold right away. After idling for a while the high side must of gotten too high and the pressure blew off for about 3 secs and I shut the engine off. I checked the pressure on the high side and found it raising into the 300s which I thought was high (ambient temp in the high 80's).
I also noticed that I missed the locking on one of the hoses on the accumulator and could not get it back in and locked so I had to evac system, refit the hose, pulled down the vac, recharged.
RESULTS: noted the high side was rising after engine idle. Sprayed water on condenser and high side dropped. Replaced the fan clutch which was about 4 years old and the fan as the plastic was cracking. High pressure side is staying down but the clutch never cycles off.
I make a few calls to tech support (vendors) and friends and can not determine if the cluth is really suppose to cycle on and off - therefore I askt he quesiton in another post.
GUAGES: about 70 solid on the low and the high is showig about 150 to start and then goes up -
WHAT HAPPENED: I was out in Palm Desert yesterday and the front seal blew out of the compressor (I think per my son who was driving it) I can see compressor oil on the engine block to the left of the ac pump. I am assuming that the pressure side may have dumped too??
QUESTIONS:
1) what is the valve/switch that located near the muffler in the a/c hose coming off the ac pump? I noted that if you disconnect it the ac clutch will not engage. I can find no part reference to this switch or reference in my shop manual. It is a mystery to me?
2) where is the high pressure dump on the compressor?
3) is there a high pressure switch on this system? I read a post that says no. If so is it the one in q1 above or ??? Where can I get one as the only switch I can find is the cycle switch.
4) does the cycle swtih control the high pressure or just respond to the low pressure to engage the clutch only if there is enough charge - or does it work to keep system from icing over.
5) should I have stayed with a lower charge of maybe 36oz per the shop manual for this system? It was blowing cold air . . . It was suggested that the system was fully charged when it the in /out of the evap was within 10% temp of each other.
As always any feedback or help would be appreciated.
Thanks in advance, Bob
QUESTIONS:
