Dirtykurty
- October 20, 2015
- Las vegas
- 1996 Explorer EB 5.0 AWD
96 EB with automatic climate controls.
I've replaced the blend door, AC compressor, all O rings, canister and freon. If I connect 12V to the compressor it'll engage the clutch but there's no power to the plug, it has recommended amount of freon according to the sticker. I've checked continuity at the low pressure switch and the switch is closed or engaged but still no power to the compressor plug at all. All fuses are good, even replaced the relay for good measure. Also have 12V going to the relay and through the fuse.
What other electrical connections should I check?
Is there a high limit switch? If so where?
