sledgehammer1990
- October 26, 2008
- Doylestown, PA
- '94 XLT
So, here is the story. I was heading home from school yesterday and I was comming up to a 90 degree turn. At this turn I shifted into first. At this time I had my clutch in and was rounding the turn. As I came out of the turn, I left go of the clutch and my rear tires started drifting to the side. My truck then started turning to wards the other lane. There was a car comming so I had to turn the wheel right, my truck then went right. There was a 1ft high stone wall on my right. My truck slid right into it causing the fron right tire to flatten. My rim bent and it looks like my tire was torn. After changing out the spare, I relized that the Locking hub would not fit in the whole of the spare. This is a full size spare of course. I had to put the spare on and the hub on the outside just till I got home. I only lived 2 minutes down the road. I drove home slowly with my hazard lights on.
When I got home, I checked out the damage. My front left tire was straight and my front right was turned outward just a small bit.
Here is the noticable damage. I will have pics up later on.
Bent Rim
Torn tire
Cracked Radius Arm Bushing
Cracked Locking Hub
I fear that my Tie Rod may be bent too. I will have to check on that after school. I did not see any damage to the rotor or that area.
What else do you think could have broken from that crash?
Bent Rim
Torn tire
Cracked Locking Hub
