Roadrunner777
- February 5, 2011
- Bemidji, MN
- 94 4x4 Sport 88k
As I recently posted, I am getting ready to retire my Explorer... but got hit with some delays because of my work schedule. The thing is (was) my right front tire was starting to show steel and I was getting some odd random steering action on the highway. So, I thought... simple enough, I'll put the spare tire on it. And, so it begins:
My spare tire appeared to be an original factory tire. It's a Firestone of the right size and vintage.... so how hard could this be?
Plan A was to put it on the right back and rotate the back to the front to match the tires on the front axle. Nope. Right rear rim will not come off... too much corrosion I suppose. I hammered and pried to the point where I might damage THAT tire, and I didn't have time to do the penetrating oil deal.
Plan B was to put the spare on the right front, directly replacing the bad tire, and live with whatever mismatched tires do. Right front comes right off. I slide the spare on over the manual hub... it won't go. The center hole of the spare tire rim is simply too small, and not by a little bit either. No choice but to put the bad tire back on.
Plan C was the winner. I took the Exp to the tire shop and had them swap the spare tire on to the existing front rim. cost me $22 and it actually drives pretty good.
So... I can't imagine anyone here has not used their spare tire at some point, but if you have not... I know it would be a pain to check, but if you really want to have confidence that your spare is going to work for you, you might want to check this. I really can't make sense of it except that perhaps the spare was intended for a 4x2?
Oh well!
(someone asked about my repair manual set... hang in there, I was scheduled for 60 hours this week, so not a lot of time yet.)
Oh well!
