Roadrunner777
- February 5, 2011
- Bemidji, MN
- 94 4x4 Sport 88k
In an earlier adventure, I discovered some play in my bottom ball joints when the x is supported by the frame. I was not at all surprised and I have seen enough suspension to know I can drive this for a while yet. But, I thought why not add a zerk fitting and pump it with some grease. Nothing to lose.
So, I am being completely careful about getting any debris in the ball joint. I greased the drill bit and had a magnet on hand for good measure. The drill got through the bottom, I was so careful. I pulled the bit back out, and a stream of rust dust follows the bit out. I got the air hose and blew a lot more dry rust out the hole. Apparently, my ball joints have been running on powdered rust instead of grease.
I tapped the hole (1/4-28 bottoming tap), threaded in a zerk, and packed it up. May not make any difference at all, but I feel better knowing it's got some actual lubrication, probably for the first time in years.
If you are thinking of doing this, it's pretty easy if you can get the frame up high enough to get the drill under the ball joint. I used zerks with the shortest thread I could find so it would not interfere with the joint inside. You definitely need a bottoming tap to complete the threads before touching the ball. I am only doing the bottoms... I see no easy way to do the top ones.
