Do you believe some problem with sensor bi metal o air cleaner duct or vacuum motor ?....thank !
...Do you believe some problem with sensor bi metal o air cleaner duct or vacuum motor ?...)
i would not expect those to cause the problem.
first, try turning the key ON for 2 seconds then OFF for 10 seconds, repeat 2 more times. does engine start up and stay running?? this builds up fuel pressure if there is a pressure leak.
check fuel pressure and pressure leak (how much of a pressure drop after 1 minute)
if not, and if you have access to a scanner...check the IAT (Intake Air Temp) sensor and the ECT (Engine Coolant Temp) sensor with a scan tool to see if they are reading the correct temps.
also, the IAC (Idle Air Control) valve may be dirty.
Thanks Cjones...I did this test and it worked well for me..!!...In the morning, until now, the motor runs perfectly when I start in the first attempt. What does that should to ?...........
ohh..very interesting your comments Cjones....and..so.......How I can check the fuel pressure ? Some especial method ?....
