- February 9, 1999
- Vail, Arizona
- 1992 XLT 4x4
These recommendations to "just get the biggest camber shims available" are not likely to do much to fix the problem... Those shims adjust the CASTER as well, and if they are not the correct size it could result in improper caster even though you might be able to dial in the camber to where it looks good.
If correctly sized and installed it does not "have to" adjust caster, but yes, you can install them to mess with caster and camber..
The "book" way to do it is to install 0° bushings on the upper balljoints, and THEN take a reading on how far off both the caster & camber are, then select an appropriate degree bushing to correct it
Its amazing how many shops don't find out where you are first.. then adjust...
FWIW, I've done all my alignments at home using fully-adjustable 2-piece bushings that do not need replacing each time a different degree is called for.
How do you check caster at home? I've been trying to figure that out for a while. I was thinking of taking it in to find out what the computer says.. then measure it myself and see what I get...
