- February 18, 2009
- Winnipeg, Manitoba
- 04 Mustang GT
Well,
Both heads are leaking now. 251,000 kilometers on the motor.
I better get started.
Im starting to order stuff now.
2 X Heads – Ebay – Clearwater Cylinder Heads – 5 year warranty - $200.00 each + shipping ($510.00)
Rocker assy @ Push rods PART # F-40 KIT http://deltacam.com/ - $225.00 + shipping
Fuel stud rail bolts x 6 (I broke one previously) STUD M8X33M8X45 EXT http://www.trademotion.com (40.55)
Fel-Pro Head Gasket rebuild set HST9081PT1 http://www.rockauto.com/ $147.79 + $20.00 shipping ($167.79
Fel-Pro Head Bolts ES72794 http://www.rockauto.com/ $32.79 + $20.00 shipping (52.79)
Looks like I'm in to this for $996.00 + to do this right.
I don't think I need lifters, as there is no real noise coming from the motor. (Except on startup it can tick for a bit) Although they are cheap at $9.00 each from http://www.mizpahprecision.com/pricing.htm (item 2244)
So, I'm kicking around doing a slight port matching job to the intake of the heads and lower intake manifold. It doesn't look hard, as I will stay away from the valve seat area. Hmm...What to do?
Another thread was done that is fantastic, and I want to make sure anyone doing their heads see's this.
http://www.explorerforum.com/forums/showthread.php?t=289847&highlight=ohv+head+replace&page=3
Many thanks to the author. This should be a sticky as it has everything thats required to do your head replacement. It sounds like more and more heads/gaskets are failing.
Im also wondering if it might be easier to stop by an exhaust shop and have them remove (and reinstall lightly) my exhaust manifold bolts as I'm driving home for the tear down. This might save a ton of pain.
