wanderer351
- September 10, 2000
- Columbus,OH
my 2002 4.6L 5r55w 97,000 the tranny has rattled since I got it about 8000miles ago...finnaly got it into the trans shop and heres what they found out (no pics sorry)...
the rattle was at idle and anytime the converter wasnt locked up (I.E. highway)...so I assumed it was turbine blades inside the torque converter...I was WRONG...
the owner of the shop (browns transmission in newark ohio) told me that they have gotten a few in and its usually the converter bolts have backed out and its always sounds like a flexplate rattle (or heatshield rattle)..he found 3 of them very loose and tightened them up a bit and it did quiet it down some..but he was sure that the studs had smashed threads and ordered a new converter and flexplate...
the old flexplate showed wear marks and even an indentation of where the 3 loose studs had begun to wear thru the plate...the converter studs showed damage at the very base of it and couldnt be tightened any more without risk of snapping them off...
the new converter and flexplate has finnaly quieted my diesel explorer!!!
ALSO...the chattering that I felt from the rear end (I assumed to be worn transmission clutches) was in fact some NASTY rear differential fluid that was basicaly useless and allowed the limited slip clutches to grab and jerk...the new fluid has made an amazing diffrence and he suggests changing it again in 6 months to get a good flush....he gave me a tip that the rear end when drained thru the plug and the remaining fluid below the drain plug level vacumed out..there is enough room to get the friction modifyer pumped in thru the drain plug so your not fighting the darn bottle into the main fill plug!!
now onto the dang leaking power steering rack (2 bottles of Lucas already ran thru it..its hosed)....and then some tires on her..and shes done with maintenance for a while....
