- April 16, 2002
- British Columbia
- 93 4 dr 4x4 manual XL.
I have a 86 Honda civic as a run-around to save gas.
It ran like a dream originally, but once in a while would start shaking like a crack-***** and stall if you let the rpms drop.
After a while the crack-***** symptoms have become the norm, and I can't figure it out.
I removed the carb, tore it down, cleaned it and rebuit it to find it is doing the exact same thing, and the carb seems to be doing everything it should be doing (no vacuum leaks anywhere either)
When it runs good it purrs, but only when the rpms are up, let them fall and it shakes and dies
I suspect an ignition problem, it seems like it actually doesn't fire on all cylinders.
The spark plugs and wires are new, and it is nice and clean under the distributer cap
It doesn't have points, it has that electronic gizmo in the distributor.
Could that be dying?
Should I scrap the Honda?
Anyone know a website that might help?
I don't want to spend all kinds of money on it obviously.
