Texasplorer
- December 27, 2001
- Austin, Tx
- X'ing 4x4
Door Blen Actuator question
Hi all.
As you know my heat does not work. So I decided to go behind the glove box and take out the actuator (spelling?) which looks like a little plastic box with a PIN about 1.5" long. Anyways while still having it connected and OUT I wanted to see if the Actuator pin would turn and it did not.
My question is, could I, or should I see the Actuator PIN turn at least while I either turn on the AC/HEATER from hot to cold w/o it being inside and just connected with the wires still hooked up? I am thinking that my actuator might just be bad and the pin might be locked up. Can anyone please helpe me w/ this? Thanks a bunch all.
Hi all.
