- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
OKay a while ago I read a post on the boards reagarding a magaizine add that advertised eccentric camber adjustable axle pivot brackets for TTB equipped trucks. Now as you know most 4x4 ttb lift kits use axle pivot drop brackets to keep camber in check.
My idea is to see if these adjustable drop brackets would work well with bent beams, allowing you to run a 3" cut and turned I beam with these drop brackets and say a 5.5"-6 lift coil and still be able to dial in the camber......
