Purplehaze
- September 15, 2012
- Gallipolis, Ohio
- 1999 Explorer XLS 4.0 OHV
Hello,
I had read somewhere on this sight a while back about a trick you can do to the AWD models, or the 4x4 that only give you the Auto select, 4 high, and 4 low option on the dash. The trick was supposedly to tap into the "brown wire" and add a switch, allowing you to trick your truck into running rear wheel drive only.
I just have a few questions, and appreciate any help I can get. Thanks
Trent
Trent
