harister
- October 29, 2013
- Youngstown OH
- 1993 Explorer 2 door
Ok, so I have a problem - there must be a solution, but I cannot see it.
The check engine light comes on, then goes off, every three seconds. When it's off, the engine runs fine, when it's on, the RPMs cut in half, it misses, and it has no power / won't go into top gear. It's a 1993 Sport with 71k that had been sitting.
It has had a complete tune up, new fuel tank, sending unit, plugs, wires etc, and I've put 2k miles on it. This began in wet weather.
The engine is not storing codes. With the engine off/ignition on test, it just flashes 111, but with the engine on test, the light doesn't stay on long enough to collect a reading.
I'll start with the coil pack, but does anyone have any suggestions after that?
