Where did you get the billet grill from? I like the Ford emblem in the corner, looks cool! Also, did you remove the stock grill? If not, did you paint it black?
Thanks for the info,
Michael
PS: the rear tails look great! I need to wet sand mine because they are kinda cloudy looking. How do you go about doing that. Just wet the sandpaper or what?
i really really like them tailights! I was going to buy some Altezzas off Ebay, but i think i just found a better looking, cheaper alternative. I MIGHT tint them if i get smoked headlight covers. If i do, im going to get totally blacked out head and tailights, to match my Limo tint.
Really nice job, and good writeup. I really like that mod. It looks good.
MrDriggan: The billet grill i got off ebay... Commonly refered to on these forums as "the ebay billet grille." Personally i dont really like it all that much. It is cheaply made and simply attatches (via zipties) over the stock grill - kinda tacky. I want to buy a carriage works or Trex or Trenz grille because they look much better and the fit is better because they go in place of the stock grill shell. - And no i didnt paint the stock grill black because my grill is blue from the factory and it hides pretty well behind the billet.
As for wetsanding. You need to buy "wetsanding" paper from your local autoparts store. Get a nice fine grit paper. Then you will soak the sandpaper in water for a few minutes. Then u will sand the painted surface with the wet paper making sure to keep the surface wet for lubrication the entire time. I think instructions on wet-sanding might come on the package of wet-sandpaper.
DroppedKamelion: Altezzas are played out.. get in on the taillight tinting and such before it becomes as played out as altezza tails.
BBQ_HotDogs: They are 20"x8.5" Mondera B-52's. i beleive u can get them at www.superbuytires.com for some rediculously cheap price. I got them im 2002 and they were much more expensive (even though i was gettin a super deal on em at the time). www.monderawheels.com is the manuf. website.
How did you attach the Ford emblem to the front of the grill? And is that the "Ebay" grill that "has more bars than other billet grills" for like $69? I kinda like the looks of it, but if its cheap...I may look else where...
Originally posted by mdriggan How did you attach the Ford emblem to the front of the grill? And is that the "Ebay" grill that "has more bars than other billet grills" for like $69? I kinda like the looks of it, but if its cheap...I may look else where...Also, did you have to modify the hood release latch under the hood?
I used 3M double sided foam tape to secure the emblem to the grill. Its really stuck on there. It doesnt come off under the force of a pressure washer so it must hold pretty good.
But to answer your question, Yes one 3oz Can of the Testors Translucent Candy Apple will be anough. You will use most of it, but you shouldnt need 2 cans of the stuff.
You will need more than 3oz of tint spray tho, but i dont reccommend using the testors tint spray; use the automotive taillight tint spray, because it comes in a bigger can, and its designed specifically for this purpose
