kstrading
- June 25, 2003
- central ks
- 2009 Explorer XLT
1992 Ex symptoms: Cold start ok but idles high. Rough re-start 10 min. after warm. Idle won't settle in, runs high and usually stays up around 1500.
What I've checked/replaced:
Motorcraft plugs & wires
Propane test for vacuum leaks.
Swapped coil packs, swapped ignition control modules.
New Motorcraft fuel pump last year.
Sensors: new MAF, ECT, ACT, TPS, IAC, CPS
Computer resets after changes.
Did leak down test on fuel pressure: key on: 36 psi, running: 28 psi.
leaked down to 20 psi in 30 minutes.
Codes: koeo: 111 (pass) koer: 411
Injectors? FPR? Need your advice. Thanks.
