Hmmmm, I could use the MAF to measure the air ingested, the raw volume of the engine won't work since the engine runs under vacuum most of the time. But, even with that info, the actual efficiency of the fuel combustion plays a significant part in how much power is achieved from the fuel.
I've read of guys with 5.0 Explorers getting upwards of 25 mpg at highway speeds and with the 3.73 gear ratio, they're turning more like 2500 rpm at those speeds.
With 3.27 gearing, 2100 rpm, similar aerodynamics and at least 600 lbs less weight, I don't think similar mileage is an unreasonable expectation.
So to, there are guys with 5.0's in their Rangers that report low 20's in daily driving and high 20's on the highway using the 3.73 gears. I should be able to get close to those numbers.
I might be wrong, but I'm convinced I'm fighting a mechanical problem that is killing efficiency. I'm guessing it's a problem with the valve train -- maybe a cam the PCM does not know how to manage, might have made a mistake when I lapped the valves or jpossibly the initial incorrect cam position sensor timing caused valve damage. One thing is for sure, it's extraordinarily unlikely that the 2nd 5.0 will have the same problem as the current. If it does, the problem will have to lie with the wiring or manifolds, both of which are really, really unlikely.
On the upside, if the replacement 5.0 gives similar issues as the current, I'll have a full set of intake and exhaust manifolds along with the wiring to swap those in as well.
